1990 740 base wagon running rich
Old Nov 1, 2011 | 04:47 PM
ringo's Avatar
Default 1990 740 base wagon running rich
i love my wagon. i work out of it and more. i take care of it and maintain her. i noticed a drop in gas mileage and then the check engine light came on. detected and 2.2.1 code and discovered it was a regina system. replaced o2 sensor with an oem regina sensor. same very rich symtoms. please help.
Old Nov 2, 2011 | 10:35 PM
Check real good for vacuum leaks. Elbows and such.
Old Nov 3, 2011 | 06:44 AM
ringo's Avatar
Default 740 running rich
thanks for the tip.
i looked for vacuum leaks and have not found any yet, however, i drove it a little yesterday and the "check engine" light came on. the same code of 2.2.1.
what now?
Old Nov 3, 2011 | 10:06 PM
swiftjustice44's Avatar
Check and or replace the engine coolant sensor. When it fails, it can provide a false (super cold) temp reading to the ecu causing rich conditions. Also, the 90 model had a TSB issued by Volvo offering a solution to the cold start injector running too long. Originally set up to run x seconds depending on temp, the solution is to wire the injector to the starter so it only activates during actual starting attempts.
Old Nov 5, 2011 | 08:50 AM
ringo's Avatar
Default runs rich after warm up
after replacing the regina o2 sensor and checking for vacuum leaks the engine suddenly runs rich after full warm up.
what now?
Old Nov 5, 2011 | 08:53 AM
ringo's Avatar
i replaced the thermostat a few months ago. where is the temp sensor? i only see 4 injectors. where is the cold start injector?
Old Nov 5, 2011 | 09:40 AM
The engine coolant sensor is under the intake manifold mounted to the head by cylinder 3. There is a gauge temp sender by #2...don't confuse them. After locating the cold start injector, temporarily disconnect it for a day or two and see if it makes a difference. It has an electrical connector similar to the main injectors.
Old Nov 6, 2011 | 07:25 AM
ringo's Avatar
would the temp sensor failure cause a 2.2.1 code? how would i really know that this is the problem?
Old Nov 6, 2011 | 08:31 AM
dieselsnowmobile's Avatar
Here is a very helpful link:
Engine Sensors
I would bookmark this site.
ECT when bad tell the ECU that the engine is colder then it really is and dump extra fuel in then needed, hence you are running rich. The ECT is way back there. There are two coolant temp sensors, one for the gauge on your dash, and one for the ECU. The ECT is a rectangle, while the one for the gauge has a rounded top. Hope that helps.
Old Nov 7, 2011 | 06:49 AM
ringo's Avatar
thanks for the help! i have located the senson on the engine. i have a regina system. do i need to get a regina temp sensor?
Old Nov 7, 2011 | 07:37 AM
From what I have researched, the Bosch and the Regina ECTs are the same.
junkmorning
Mar 23, 2005 10:51 PM
Mannkar
May 22, 2004 03:34 PM
Mannkar
May 19, 2004 02:48 AM
Mannkar
May 19, 2004 02:15 AM
