1990 740 GLE. Stalling.
Old Sep 30, 2013 | 07:35 PM
Dave132's Avatar
Default 1990 740 GLE. Stalling.
I'll try to make this short and sweet. My car began to die a lot on random occasions about 2 weeks ago. I replaced the spark plug cables and spark plugs and checked my battery. It definitely has more power and idles a lot better, but the car dies still if I drive it to my location then start it up again. The weird part is that it runs great on the third try. But if I turn the car off then on again it will die shortly after. It's a pattern. I can't figure this out.
174,000 Miles. Just had a tune up. Oil is clean.
Old Oct 1, 2013 | 12:25 AM
Titan Joe's Avatar
I could be the crank position sensor going bad. It would get worse pretty quick. So it's not likely. I'd check and make sure that the grounding wires on the intake manifold are making good contact. Then I'd look into your fuel injection relay. Sometimes they get finicky due to cold or cracking solder joints.
Old Oct 1, 2013 | 12:41 AM
a 740GLE, is that regina or bosch LH 2.4 ?
Old Oct 1, 2013 | 06:59 AM
Dave132's Avatar
It's Bosch. Not sure if this matters, but it's dual overhead cam. I'll check the wiring. I just bought a new coil pack to throw in. My current one looks very worn. Would that make any difference?
Old Oct 1, 2013 | 10:26 AM
these cars dont have 'coil packs'. they have a plain coil, and a power module. Bosch coils almost never fail, but the power modules give up the ghost sometimes.... however, your symptoms seem more likely to be the fuel pump relay or the CPS, or something similar. note thats just 'more likely', diagnostics are needed here to determine whats wrong, rather than just throwing random parts at it.
Timmy Hogan
Apr 28, 2012 07:56 PM
junkmorning
Mar 23, 2005 10:51 PM
Mannkar
May 22, 2004 03:34 PM
Mannkar
May 19, 2004 02:48 AM
Mannkar
May 19, 2004 02:15 AM
