1990 740 wont start please help
I have a 1990 740 and it was running fine until i went out one day and it wouldnt start. It cranks hard but just wont start. I dont hear the fuel pump kicking on. The white fuel pump relay clicks i checked 2 fuses for the fuel and there both good but i dont have power and the in tank fuel pump fuse with the key on. Any suggestions? What else should i check? Is that fuse suppose to have power all the time? thanks for the help
The white relay should click twice. Once when turned on and again when you crank.
On the side of the relay there should be a date how old is the relay?
Ok i will have to check the relay for the second click. I will check tomorrow. Also shouldnt i hear the fuel pump kick on after the first click? Cause i hear nothing.can i jump that relay and get the car started if it is the relay?
playa7970
Sep 23, 2008 11:50 PM
Black Belt Turbo
May 12, 2006 08:40 PM
