1990 Dl 240 rear wiper motor
Old Dec 23, 2009 | 06:07 AM
darkdelta's Avatar
Default 1990 Dl 240 rear wiper motor
1990 DL240 Wagon
My rear window wiper never stops in the same place when turned off at the switch. I watched the motor with the trim panel removed. The intermittent setting, just moves the blade a little bit then stops.
My thinking is the park switch is somehow defective. Before I remove the rear wiper motor, does anyone know if this is repairable or am I looking at buying a new motor?
Thanks in advance.
Old Dec 27, 2009 | 09:53 PM
hotcrowd's Avatar
Hi darkdelta,
My car is the 90 240DL wagon. I have had the front wipers do a similar behaviour, and fixed it by cleaning the contacts on the wiper switch stalk on the steering column. Sprayed electrical contact cleaner (CRM brand) then followed that with DeOxit cleaner/lube. Cleaned all the fuses that way too. Lubed the wiper linkage just in case with Garage Door Lube.
As for the rear wiper/motor/assembly/circuits; could the wiring through the rear hatch hinges be severing? Otherwise, give the stalk contacts attention.
Hope this helps. Best of success.
Brandon in Franklin,TN
Old Dec 28, 2009 | 10:23 AM
blue goose's Avatar
Sometimes the magnets become dislodged from the housing and slip down onto the armature causing erratic operation. I would pull the wiper motor and have a look at the insides. Worst case you're looking at a new motor. Better yet, one from the junk yard. Usually the rear motor doesn't get used much.
Old Jan 29, 2010 | 03:13 PM
darkdelta's Avatar
Default Wandering Rear wiper solved!
Hello Fellow Bricksters,
I had noticed the tailgate harness was looking rather worn, so I replaced both sides, and then the rear wiper problem was solved. It wasn't such a bad job.
Maybe this will help someone.
garves80
Feb 21, 2011 10:33 AM
procopycenter
May 17, 2009 01:17 AM
summit
Nov 15, 2008 09:22 AM
mrpyromaniac
Sep 15, 2007 08:41 AM
Cape Islander
Feb 26, 2004 11:13 PM
