1990 DL 240 Wagon
1990 DL 240 Wagon
I have an automatic transmission, and the shifter has an extreme amount of play in it (front to rear). The interlock to prevent accidental movement to reverse is intact. Anyone ever expierence this? If so what is the best plan of attack. Also is the PRN . . . selection lighted?
Thanks in advance
Thanks in advance
RE: 1990 DL 240 Wagon
I had a '89 wagon that had a similar problem. I never really did anything to fix it but when I recently removed the transmission I found the linkages that connect to the transmission were pretty worn. Don't really know how you might tighten them up.
Also, yes there is supposed to be a light in the shifter that illuminates the gear you are in. I believe this light only comes on if the lights are turned on.
mattem
05-14-2020 08:39 AM
craigshensel
06-13-2012 03:11 PM
