1990 Volvo 240 DL no fire won’t start
Old Jun 17, 2023 | 02:41 PM
MLaney's Avatar
Default 1990 Volvo 240 DL no fire won’t start
Hi I’m new here and trying to help my son.
his Volvo turns over but won’t start.
I’ve replaced the coil, the distributer cap and rotor, and the crankshaft position sensor. After replacing the CPS it ran great and then just stopped again.
i replaced all four components again and this time nothing.
any help would be appreciated.
mitch
Old Jun 17, 2023 | 03:46 PM
What codes area stored? Do you know how to check them? Is the fuel relay working properly? Do you have injector pulse, spark, compression, cam timing is correct and what's the fuel pressure?
https://www.volvoclub.org.uk/faq/EngineOBDCodes.html
Old Jun 17, 2023 | 07:53 PM
Psaboic's Avatar
A poor man's quick way to troubleshoot is to get a can of starting fluid. Spray about a 2 second burst of starting fluid into the air filter intake (engine side of the filter housing) and try to start. If car tries to start or starts and runs for a second or two, then you have good spark and a fuel delivery or injector problem. If it doesn't try to start, then you have a spark/electrical issue. Once you know if it is a fuel issue or a spark issue you can troubleshoot further. Main thing is please stop throwing parts at it as that will get real spendy real fast.
Old Jun 18, 2023 | 05:04 PM
MLaney's Avatar
it doesn’t seem to have codes stored. We can check them. Relays and all seem to be working just no spark at plugs.
Old Jun 18, 2023 | 05:06 PM
MLaney's Avatar
Default No spark
It’s pumping fuel to the injectors. No spark at the plugs.
Old Jun 18, 2023 | 09:23 PM
If the injectors are firing (making a clicking noise you can hear with a stethoscope, or a flash on your noid light) that means the engine speed sensor is working. Is there spark at the coil? (I've seen plenty of bad distributor rotors)
Old Jun 30, 2023 | 07:15 AM
MLaney's Avatar
Default Update
The problem was the ignition control module. It wasn’t allowing the coil to fire so no spark anywhere. Replaced the ICM and problem solved.
Nellynell30
Sep 15, 2017 05:55 AM
volvo84
Engine & Internal
Dec 17, 2013 09:41 PM
dldunckel
Jan 20, 2010 07:02 PM
nathan7h
May 18, 2009 07:50 PM
