1991 240 ECU Fuel Pump Relay Problems
Old Jun 27, 2012 | 10:24 AM
dlukowsk's Avatar
Exclamation 1991 240 ECU Fuel Pump Relay Problems
The Situation:
Over the weekend my 1991 Volvo 240 just died. I had it towed back to the house. I started trouble shooting and found that the fuel pump was not engaging.
Troubleshooting:
All the reading I've done here says start with the Fuel Pump relay. I replaced it. No go. I then put the old relay back on with cover off it. so I could watch it.
Fuel Pump Relay
Ignition OFF:
Pole 30 = steady 12V.
Ignition ON:
First pole (86/1) and (87/1) engaging.
Ignition to START:
Second pole (86/2) and (87/2) DOES NOT ENGAGE.
ECU LH2.4:
Both the ECU and the ECM are pulling codes 1-1-1. So all of the inputs appear to be in working order.
I went through all the tests in the Bentley Manual for the LH2.4 system testing each lead on the unit with a Multimeter. The ECU Passed Every test.
The fuel pump relay test, when I ground ecu lead 20(Bl/Grn) that runs to the relay it engages the first pole on the relay. If I ground both leads 20(Bl/Grn) and 21(Yl/Bk) which go to the relay, both poles engage and the fuel pump runs.
I opened and visually inspected the ECU. There were no burnt leads on board. It visually looked fine.
Conclusion
Lead 21(Yl/Bk) is not supplying the proper ground as it should when the key is turned to the START Position. ECU otherwise is working fine.
Workaround
Since lead 20(Bl/Grn) is supplying the proper ground when the key is turned to ON, I have spliced together 20(Bl/Grn) and 21(Yl/Bk) on the relay side. When the key is turned to ON the fuel pump will begin running. When it is turned off, the fuel pump will run for approx 5 seconds and turn off.
Looking for the correct fix
So, with all the information I've provided does anyone know what the proper fix for this problem is? I feel like I've run out of things to test. I've done everything short of just starting to randomly replace parts.
Also, does anyone know if there is negative ramifications of doing the workaround I've done above?
Old Jun 27, 2012 | 03:57 PM
that car probably has the double relay (some have two separate relays), where one relay powers the fuel injection system, and the other powers the fuel pumps.
FWIW, with LH2.4, the fuel pump relay should only engage for about a second when you turn the car on to pressurize the system, then stop again until the crank position sensor indicates the engine is turning (eg, when you crank the starter, or when the engine is running). the fuel *injection* relay comes on with the igntion key and stays on until the car is shut off.
Old Jun 27, 2012 | 05:14 PM
dlukowsk's Avatar
Correct double relay, not two separate relays. I've attached a picture of the pinout. I have a tachometer which is where the ECU supposedly receives it's rpm signal from and it is working. Right now the only thing I can assume is the ECU is bad, because it's not throwing any codes, yet not grounding 86/1(Yl/Bk) after cranking.
Attached Thumbnails 1991 240 ECU Fuel Pump Relay Problems-fuel_pump_relay.png
badcircle
Nov 21, 2011 11:10 AM
spidersilva
Aug 17, 2011 07:23 PM
montysano
Sep 9, 2008 11:52 AM
dstinsman
Jan 13, 2008 10:59 AM
