1991 240 Won't Start - Fuel Pump?
Old Jan 13, 2008 | 10:54 AM
dstinsman's Avatar
Default 1991 240 Won't Start - Fuel Pump?
Just bought this car. Noticed when I bought, fuel gauge works only intermittently. Yesterday, car won't start, starter sounds like it's trying. Not the battery because lights/radio work. Checked the manual and the previous owner highlighted info about the #4 fuse (fuel feed pump heating element) and the engine control system fuse. Took out the fuses, put them (same ones) back in. Car started. Today, same thing happened, except that "fix" is not working. Still won't start. What could be the problem?
Old Jan 13, 2008 | 10:59 AM
Default RE: 1991 240 Won't Start - Fuel Pump?
It might be the fuel pump relay.
You will have to check for power to the fuel pump when the key is just turned on or cranked over.
Luchy72v
Nov 25, 2013 10:06 AM
240Matt
Apr 21, 2013 06:55 AM
dlukowsk
Jun 27, 2012 05:14 PM
badcircle
Nov 21, 2011 11:10 AM
