1991 240 Horn not working
Old Mar 31, 2015 | 10:04 AM
Rich240's Avatar
Default 1991 240 Horn not working
Hi all,
I read posts about horns not working and troubleshooting and am looking for further help. The wipers work so I kind of ruled out fuse. I checked connection at the horn and they appear fine. I kind of loose the wires from the horn when I'm tracing because they go into a black sleeve under the hood. So I'm not sure where else to look under the hood for wiring. I tried to take the air bag off to check wirinig on the steering wheel under the air bag. While trying to take the bottom steering column off I noticed there is apparently one screw for the steering column behind the leg well area and I can't get to the screws of the air bag without removing the bottom part of the steering column. Is there anyway to remove the bottom steering column without taking off the entire leg well thing?
Thanks
Old Apr 1, 2015 | 06:45 AM
act1292's Avatar
What is the "leg well thing"? If you are referring to the knee bolster, it needs to come off. It's only held on by two torx screws.
Old Apr 1, 2015 | 08:53 AM
Rich240's Avatar
Cool, thank you!
Old Apr 3, 2015 | 11:51 AM
jagtoes's Avatar
If the horn doesn't work just use your finger.
Old Apr 7, 2015 | 01:25 PM
Rich240's Avatar
That has been used as well, lol.
Old Apr 21, 2015 | 07:13 AM
Rich240's Avatar
I tried to unscrew these two torx screws, but they are very content on staying where they are. Is there any other way to get to that hidden screw. Or an easier way to get the airbag off of the steering wheel? Where are the wires for the horn coming from the steering wheel coming out into the engine bay located?
Thanks
Old Apr 21, 2015 | 01:39 PM
you need the suitable sized torx bit for a 3/8" or 1/2" ratchet, they are fairly big bolts (but I forget what size), a fair bit of torque. same as the seat belt anchors, they are part of the cars safety system.
Old Apr 22, 2015 | 06:15 AM
act1292's Avatar
In my experience, the knee bolster bolts can be removed using the torx screwdriver kit that came in the toolbox with the car. That is what I always used to remove it. Now if someone cranked down on them, you can use a small socket and use it to turn the torx bit from the toolkit. That should get it off.
Rosy
Sep 11, 2010 08:45 AM
ROCNYS60
Oct 3, 2008 01:22 PM
mikeeyuk
May 1, 2006 08:40 PM
KESchumacher
Apr 18, 2006 08:33 PM
gur8
Aug 14, 2005 12:46 PM
