1991 940 Cigarette lighter
Old Aug 8, 2011 | 07:38 PM
zloetakoe's Avatar
Default 1991 940 Cigarette lighter
Hi, my cigarette lighter is not working. Not needing to smoke, but I'd love to power some electronics while I'm driving. Anyone dealt with this?
Fuses are good.
Old Aug 8, 2011 | 08:27 PM
dezertsub's Avatar
Fuses, and make sure the two wires are plugged into the back of the unit. Hopefully you can just pop it out with a small flatblade and check. Suerte!
Old Aug 8, 2011 | 08:54 PM
swiftjustice44's Avatar
Radio work? They're usually on the same circuit...also, take a look inside the socket...I've seen a good half inch of ash in there acting as an insulator. The socket only works w/ key in the run position. Use a test light and see if it's getting voltage. Pretty sure I have a good used socket if you find yours is getting power and still isn't firing up.
Old Aug 8, 2011 | 09:22 PM
zloetakoe's Avatar
Radio is fine. I'll pull it out and test the wires. Also, it doesn't work even when the car is running so I know the key is in the right position.
Thanks for the help, I'll see what happens.
Old Aug 9, 2011 | 07:47 PM
according to my wiring diagram for a 92 740/940, the cigar lighter gets + juice from the ignition switch connection "X" (live in positions I and II), through fuse F14. its grounded to pin 3 of the rear window defroster switch then on to the main ground strip under the fuse/relay panel, which in turn is grounded to the dashboard ground block on the firewall.
note, if your 1991 940 is in fact a 940SE, its really a 960 and its wired somewhat differently. I don't have those prints.
newtome
Sep 25, 2007 07:47 PM
m_schiff83
Aug 10, 2007 05:06 PM
biffo19
Mar 1, 2007 08:10 PM
rjgspr
May 5, 2005 01:06 AM
rjgspr
May 3, 2005 10:54 PM
