1991 940 Starting Issues
Old Sep 11, 2013 | 08:58 AM
Joker56's Avatar
Default 1991 940 Starting Issues
I have a 91 940 GLE that will not start. I bought it with 246000 miles, and it ran, but very badly. I have since replaced the fuel pump, fuel filter, fuel sending unit, ignition coil, plugs, wires, and distributor cap. Now the car will crank and fire on a cylinder or two, then stall. Yesterday I pulled the fuel rail and injectors and cleaned, but no luck. I wasn't able to check the fuel pressure for lack of a gauge, but there was definitely plenty of fuel flow at the rail. Any help would be greatly appreciated!
Old Sep 12, 2013 | 05:46 AM
act1292's Avatar
First, make sure that the spark plug wires are connected in the right order. Second, check the alignment of the timing belt. Third, I would do a compresssion check.
The biggest concern I would have on a GLE if you don't know the history of the car is that it has dual overhead cams - which means it is an interference engine. If the previous owner broke the timing belt, it could have damaged valves. The compression check should tell.
Old Sep 12, 2013 | 11:06 AM
guest01's Avatar
Yeah, I'd double check you have the firing order right. Then check compression.
Old Sep 12, 2013 | 02:20 PM
Joker56's Avatar
Thanks for the replies. I will be working on the car tomorrow, so I will have more info to post soon.
Old Sep 15, 2013 | 12:58 PM
Joker56's Avatar
I got the car started today after replacing the injector seals. It was losing fuel pressure through the seal on the cylinder 2 injector. It runs now, but is very hesitant to throttle up. Any ideas on how to improve throttle response?
Old Sep 15, 2013 | 01:07 PM
Check the intake tube between the MAF and THROTTLE BODY. Make sure it has no cracks, splits, tears, etc.
that4wdwagon
Aug 20, 2014 04:58 PM
gel69
Sep 24, 2013 10:25 PM
Alyster940
Aug 22, 2013 01:45 PM
marclou1969
Sep 27, 2006 08:52 PM
br549
Sep 28, 2004 09:15 PM
