1991 940 Turbo Wagon Gear Shift prob
Old Nov 7, 2007 | 01:08 PM
Suzys940Turbo's Avatar
Default 1991 940 Turbo Wagon Gear Shift prob
My 1991 940 Turbo Wagon won't shift! The Gear shifter between seats moves freely once out of Park. Doesn't lock into gear. Car starts no problem in Park. Stays running no problem as shifted into other gears but doesn't seem to "register" in the engine.?! Car stays in Neutral the whole time. Am in the process of taking console out between front seats to expose the "Gear shifter" thing. HELP!
Old Nov 8, 2007 | 07:22 PM
dgm76513's Avatar
Default RE: 1991 940 Turbo Wagon Gear Shift prob
I had this problem on my first Volvo, an '82 240GL automatic. There's a clip in the linkage from the shift selector to the transmission which fell off. Replaced it with another clip. I got it from the Volvo dealership and it was about two bucks back then. That was seven years ago though. Anyways, it's worth looking at assuming you have an automatic transmission.
Old Nov 12, 2007 | 08:32 AM
Found this broken off on side of shift lever base, there is a clip still attached that broke off of this piece. (Replacement should have two clips on it) Is this what I need?
[IMG]local://upfiles/13216/A303D3C5E164476B87EE5C21792A3BD3.jpg[/IMG]
[IMG]local://upfiles/13216/7BD7991BA7F847E7AA1BD4313526775F.jpg[/IMG]
Old Nov 12, 2007 | 05:07 PM
billofdurham's Avatar
It looks like part #25 on the attached. This is part of the shift lock mechanism. Part #26 is the manual release.
The note says up to year '91 for the part number.
The second attachment shows how it all fastens together.
[IMG]local://upfiles/4491/AA1D8BC87909449497F139878D0CD9AD.jpg[/IMG]
[IMG]local://upfiles/4491/5F80AB6F04264D638C2B34DAC6C688AB.jpg[/IMG]
Old Nov 12, 2007 | 06:02 PM
dgm76513's Avatar
Mine was part #56. Gotta watch that one too, liked to fall out on mine a bunch. Finally removed the clip and safety wired it on with .032". Worked fine ever since.
andrewma
May 16, 2018 01:47 PM
vulthuryol
May 3, 2014 05:11 AM
turbo940v
Jul 13, 2010 02:09 AM
rkrine
May 2, 2010 08:31 AM
