1991 Volvo HELP
Old Mar 30, 2020 | 02:48 PM
240_Man's Avatar
Default 1991 Volvo HELP
Hello - just did an engine swap but FORGET how some of the connections go.
Firstly - please see my question on video attached.
  • Where does the BLUE negative battery cable tie down to? The engine?
  • How does the OIL separator hook up? IE Hoses?
  • There are 3 hose connections on the intake I need guidance on.
Please see my video. IF you can make a video of you 240 and explain the connections that would be a HUGE HELP
Here is a link to my video... https://drive.google.com/open?id=1-V...gcWSbOX0WEmLmS
THANKS everyone. I really appreciate your help. hessongaj@ g m a i l . c o m
Old Mar 31, 2020 | 07:29 AM
check out volvotips.com for some online documentation
Old Mar 31, 2020 | 11:27 AM
240_Man's Avatar
Thanks!!!!
Old Mar 31, 2020 | 12:10 PM
the battery negative cable goes to the chassis near the battery platform, should be a flat slot with a big bolt hole.
the vacuum nipples on the intake manifold connect to various things that need vacuum, including...
  1. brake booster (larger diameter than the others)
  2. hose through the firewall for the ventilation controls
  3. charcoal vapor canister
  4. ignition controller on 240 models up to 1988 that use Chrysler ignition (not applicable to your 91)
  5. .... anything else that uses vacuum, that I'm not remembering offhand
Injabs
Nov 18, 2012 02:33 PM
MC92
Jul 24, 2012 08:36 AM
Somthngfrce
Feb 21, 2009 08:27 PM
Rickc10ny
Dec 20, 2007 05:20 AM
ricecooker
May 26, 2006 05:37 PM
