1992 Volvo 240 Electrical Problem help pls
Old Jan 21, 2022 | 02:36 AM
Laochow240's Avatar
Default 1992 Volvo 240 Electrical Problem help pls
Hello everyone, I have a 92 Volvo 240 that has me stumped. When I bought the car the brushes on the regulator were shot so went ahead and put a new alternator, ended up putting another in later because I thought that one was bad too and a new battery. Anytime I drive the car (without using headlights) I can drive it for quite a while before the car won’t start. But if I used headlights it may last 10 miles before if I turn the car off it won’t start back. Voltage at the battery I’ve seen 13-15v is this a problem?
Old Jan 21, 2022 | 09:49 AM
Do you have 13.5 - 14.5 volts at the battery with the engine running, headlamps on, and the heater fan running? (may have to rev the engine to 1500 rpms)
If not your alternator is not charging enough - That's caused by a bad alternator, or a bad connection somewhere. I Trust the ground wire is connected to the alternator.
Johnnysaltshaker
Oct 21, 2015 02:47 AM
soli
Aug 5, 2015 07:08 PM
sarahshufelt
May 24, 2015 08:42 PM
harebearva
Aug 20, 2012 02:24 PM
AnEskimo
Oct 29, 2011 06:46 PM
