1993 240 electrical problem
About a week ago, I went to start my car. The battery had run dead (lights left on), so I had it jump started. The abs and srs lights were lit. I started driving, and the srs light went out. Then the abs light started flashing, and about 10 seconds later, the entire electrical system cut out(headlights, four-way flashers, power steering, et cetera) and the engine stopped. I tried to start it, but there was no response from the starter. I have since tried repeatedly to start the vehicle, but to no avail. Any ideas?
you can buy a cheap volt/alternator meter at harborfreight for 5 dollars.....
very easy to use:
connects to + & - terminals and has two sections...one for the battery and the other for the alt....
both methods of testing: while car on and while off.....
1) check the alternator belt tension...and the bushings on the mounting block...
2) check the grounds for corrosion or loose...
very easy to use:
Your battery is discharged, and your alternator is probably failing as well, may be due to a fault in the dash lights, may be it's worn out, may be a wiring problem... It's a combination of those, there are no fuses to check. First get the battery well charged, go from there.
