1993 940 with rough idle???
Old Mar 26, 2006 | 07:21 PM
joker834's Avatar
Default 1993 940 with rough idle???
1993 940 new plugs, wires, cap and rotor button but idle is still rough? Car runs like a top but the idle is not smooth. Where should I look next? Any help is greatly appreciated!
Old Mar 26, 2006 | 10:43 PM
Default RE: 1993 940 with rough idle???
Clean the throttle body and idle motor.
Old Mar 29, 2006 | 11:09 PM
joker834's Avatar
I cleaned the throttle body but where is the idle motor located? How/what do you clean on it? Thanks in advance!
Old Mar 29, 2006 | 11:18 PM
It is a cylinder looking thing mounted under the intake manifold.
It has 2 hoses going to it.
Clean it with either Carb. cleaner or Brakeclean.
Old Mar 29, 2006 | 11:21 PM
joker834's Avatar
Do you remove it to clean it?
Old Mar 29, 2006 | 11:24 PM
joker834's Avatar
Also what brand spark plugs and what gap should I be running in this Volvo?
Old Mar 30, 2006 | 12:08 AM
Yes you remove it to clean it. After you clean it spray a dab of WD-40 in it and try to work it some.
I perfer Volvo plugs But Bosch work good Gapped at .30
Old Apr 2, 2006 | 10:18 PM
joker834's Avatar
When you say "try to work it some" what exactly do you mean? I removed and cleaned it and put some WD40 on it and now the idle surges up and down from about 1500 to 2000 rpm's. What else can I do to it to make it function correctly? Thanks in advance!
Old Apr 3, 2006 | 09:08 PM
I meant when you had it out.
Have you messed with the idle screw at all?
Are you sure all the hoses are back on good?
Old Apr 5, 2006 | 10:55 PM
wojeepster's Avatar
check the accordian looking hose that runs froml the air mass sensor to the throttle body sometimes these get a hole rubbed in them allowing unmetered air in. You can wrap with electrical tape as a very temporary fix if you have a hole. Replace accordian looking hose. The orings sometimes go bad around the injectors, when this happens you get a rought idle at first and then it smooths out as the car warms up.
Old Jan 19, 2009 | 05:06 PM
brf0007's Avatar
did anyone ever determine the cause of this issue? Mine is having the same problem, runs fine, idles roughly. Car has new plugs, wires, and has 220,000 miles. I have checked the EGR, checks ok. Checked compression, checked ok. have checked injectors, they seem ok, as do the rings around them. I even checked the idle tensioner, nothing. Any thoughts on this?
jws
Dec 30, 2011 08:09 PM
Brandy_l
Sep 9, 2010 11:52 AM
schnepel
Mar 18, 2010 10:10 PM
hanson174
Mar 14, 2009 09:34 PM
yank50
Mar 14, 2009 11:15 AM
