1993 Volvo 240 gear shift stuck - please help!
Old Feb 16, 2008 | 11:39 AM
sredpath's Avatar
Default 1993 Volvo 240 gear shift stuck - please help!
I have a 1993 Volvo 240 that will not shift beyond Reverse. Any ideas? I have tried holding the Shift Override button while shifting gears but that is not helping.Any insight is appreciated.
Old Feb 16, 2008 | 12:38 PM
sredpath's Avatar
Default RE: 1993 Volvo 240 gear shift stuck - please help!
Update: I let it sit for about 30 min. and then tried it again and it shifted into drive (with Shift Override light on). I drove it around the block and into my driveway but now same issue, will only go into reverse and not past. Another thing is when I put it in park I have to jam the gear shift. If anyone has any insight, please post. Thank you.
Old Feb 16, 2008 | 01:56 PM
Maybe the linkage or the shifter assembly is loose/jamming.
Old Feb 16, 2008 | 06:28 PM
sredpath's Avatar
I made a mini-video showing the problem I am having. Any suggestions on an easy fix?
http://www.youtube.com/watch?v=6WyTKG292B4
Old Feb 16, 2008 | 09:59 PM
Looks like the shiftlock setup is messed up.
I piece can be removed but it will totally take out the shiftlock setup.
Obelix
Jun 20, 2022 08:40 AM
Gilles
2001-2013 model year V70
Apr 8, 2013 09:24 PM
bamaboifresh
Dec 20, 2008 07:43 PM
Lucy
Oct 1, 2006 08:52 PM
