1993 volvo 240 wagon fuel pump
Old Nov 17, 2010 | 03:21 PM
devo's Avatar
Question 1993 volvo 240 wagon fuel pump
My mom has a 1993 240 and the place she took it too wants $600.00 to change her fuel pump!
Can some please let me know where it is located and whats involved in changing it.
I am pretty mechanically inclined as far as motorcycles go so I am pretty confident I can change it I just need to know where its at and if there any procedures I should follow. I just cant see her paying that much just to swap out her fuel pump
Oh and its a wagon if that helps
Any help would be appreciated,
Dean
Old Nov 18, 2010 | 06:25 AM
act1292's Avatar
There are two fuel pumps in the car. A transfer pump that is located in the gas tank and the main pump which is located under the car, left side under where the back seat is. You need to find out which one or both are bad. Here is a link to a site that describes how to remove the transfer pump:
http://cleanflametrap.com/transferPump.htm
It also shows how you can test both pumps. If you jumper the left side of fuses 4 & 6, both pumps should run. If you hear the main but not the transfer pump, then your transfer pump is bad, etc.
Many times the transfer pump will go bad but the car will still run. This causes extra strain on the main pump and it eventually fails.
Good Luck
Old Nov 18, 2010 | 10:57 AM
devo's Avatar
Thank you very much!
Old Nov 18, 2010 | 12:25 PM
devo's Avatar
I checked out that link lots of good info. I am going to hold off and get the ipd tool to remove the sender lock nut, I am going to test it this weekend to figure out which pump it is but until then I believe her problems were that it wouldnt start intermittently and would just shut down while driving ont the street or freeway. It seems from reading up on other posts that if the pre-pump (in tank) goes bad the main will still be able to feed fuel and not vice versa is this true?
Old Nov 18, 2010 | 04:30 PM
devo's Avatar
I might as well change both of them and the relay any other parts I might need?
Old Nov 19, 2010 | 12:04 AM
volvoQ's's Avatar
I did this on a 90 740, I used a giant pair of channel locks to get that big nut off.
Old Nov 19, 2010 | 06:13 AM
act1292's Avatar
If it periodically won't start and dies sometimes while driving, it may not be the pumps at all. It may just need a relay. The relay is behind the glove box. Just remove the panel below the glove box and you should see a white square plastic box - this is the fuel pump relay.
Of course, your testing of the pumps as described in the link in my previous post should reveal whether they are working properly or not.
Good luck.
Old Nov 19, 2010 | 01:42 PM
devo's Avatar
Yep thats exactly what I am going to do I am going to pick up the relay on my way home from work tonight and give that a shot thanks.
I will post back the results
Old Nov 19, 2010 | 01:43 PM
devo's Avatar
Thats a good idea I think I have a pair some where.
Old Nov 20, 2010 | 07:22 PM
bigdaddyrdpjr's Avatar
Wink +1
+++++++++++++++1
Old Nov 21, 2010 | 01:20 PM
devo's Avatar
You wouldnt happen to know aht size they were I just checked I have a pair of 16" channel locks.
How wide is the bung nut?
Old Nov 27, 2010 | 10:35 AM
devo's Avatar
They gave me the same pump! well they gave me 2 main pumps so I gotta hit AZ and see if they will exchange one of them so I am on hold for right now.
I got the cover off the inspection plate but it looks like I will need a bigger pair of channel locks to get the nut off so I am on hold for the time being.
Oh BTW my Mom is going to give me the wagon so now I am the proud owner of a 1991 Volvo 240!
Now I just need to get her running so I can drive her home.
Old Nov 27, 2010 | 06:00 PM
lev's Avatar
lev
you don't need a special tool for the bung nut. just use a piece of wood and tap it lightly CCW and it will come off... it's the easiest part of the job...
Old Jan 14, 2011 | 06:05 PM
devo's Avatar
Ok here is an update I ordered 2 Delphi pumps from Rockauto and I opened the Delphi box and what do I find, AIRTEX pumps! Good thing I read the clean flame trap post like 20 times. I checked the part# etched on the pumps and both are AIRTEX part #'s. Are AIRTEX any good? or should I send them back?
Old Jan 14, 2011 | 07:12 PM
jagtoes's Avatar
LOL I was just going to tell him the same thing. I just did mine last month.
jws
Dec 30, 2011 08:09 PM
spidersilva
Aug 17, 2011 07:23 PM
klart
Jun 7, 2011 06:53 AM
montysano
Sep 9, 2008 11:52 AM
