1995 940 AC Compressor Rarely Engages?
Old Aug 18, 2014 | 01:51 PM
Spyros's Avatar
Question 1995 940 AC Compressor Rarely Engages?
Hello all! So this issue started last week, at first I was driving and all was normal, then I noticed the AC wasn't blowing cold for about 4 minutes, then it came on again for 1 minute, then off again. On this day, the air blew cold for about 1 out of every 5 minutes through hours of driving.
The next day, it blew cold for about 5 minutes when I first turned the car on. Then it did not work throughout the day. Let the car sit for a few hours until night time, at night the AC worked fine.
After that night, I am lucky to have the compressor kick on for 1 minute, if the car's been sitting for a long time. Generally, the AC is not working at all now.
Important notes!
1. When I switch on the AC from the button, I do hear the normal quiet click 4 seconds later, which tells me some "signal" is being sent to turn on the compressor. The compressor does not respond.
2. I checked the system pressure, and when the compressor IS ON the pressure is in normal range.
3. When the compressor has turned on in the past few days, the AC blows normal, very cold, no issues when it's functioning. Compressor gets cold to the touch.
4. When AC is set ON, and temp control is set to coldest setting, compressor still has not been turning on, and remains warm to the touch.
So, does this sound like a relay, or a fuse, or is my compressor shot? Thanks for help/advice!!
Old Aug 18, 2014 | 01:54 PM
when my system was low on R134a (it was converted), the compressor was kicking on/off/on/off at about a 8 second cycle (2-3 seconds on, 4-5 seconds off).
the signal from the dashboard control goes to the pressurestat in the reciever/accumulator, then to another pressurestat in the condensor manifold (lower left corner of the radiator), then to the compressor solenoid. one pressurestat is 'high pressure' and the other one is 'low pressure'. the pressurestat switch opens if its 'wrong' (in whichever direction that pressurestat works).
Old Aug 18, 2014 | 02:18 PM
Spyros's Avatar
pierce you are the greatest!! I'm not clever enough to know what to do with the information you gave me, but I think you are super awesome anyway! You're so nice!
Bjones822
Jul 8, 2015 05:03 PM
Athilla
Aug 31, 2010 10:49 PM
PLCguy67
May 15, 2010 12:15 PM
HummerGuy
Jan 9, 2009 02:00 PM
Aopocetx
Dec 5, 2008 08:12 AM
