1995 940 with irs?
Old Jun 4, 2015 | 07:42 PM
Moetheshmoe's Avatar
Default 1995 940 with irs?
I've heard many times that the only 940 that had the irs was the 91 SE but there's a guy locally who claims his 95 940 has it. Is this possible?
Old Jun 4, 2015 | 09:23 PM
lev's Avatar
lev
No! A 960, yes, not a '95 940...
Old Jun 4, 2015 | 10:39 PM
Check this out:
1995 95 VOLVO 940 TURBO sedan !!!original owner!!!
The emblem on the trunk says 940 and he's bragging about his irs. And he's calling it a factory upgrade.
Old Jun 5, 2015 | 01:08 AM
REVOLV's Avatar
pic 18 schmo
Old Jun 5, 2015 | 08:54 AM
I saw that but I can't tell, not clear enough. Seems like, even though he's the original owner, he believed the salesman's pitch.
Old Jun 5, 2015 | 10:25 AM
lev's Avatar
lev
I didn't see IRS mentioned in the ad, may be he realized...
Besides that, lots of BS there: over 30 mpg (never gonna happen), $700 for pads and turned rotors (somebody got screwed), great interior (except for the driver's seat), etc.
This car is worth a grand...
Old Jun 5, 2015 | 05:13 PM
960 sedan was IRS and I suppose someone could have put a 940T motor in a 960, but thats no 960, not with that front end and dashboard...
Old Jun 5, 2015 | 05:25 PM
in .eu and nordic, the last year for the 960 redblock turbo 4 was 1994 per my VADIS catalogs. in 1994, a 960 turbo sedan was multilink (IRS). in 1995, the 960 was whiteblock only.
Old Jun 5, 2015 | 08:05 PM
My fault, he said multi link which is irs, right?
Old Jun 5, 2015 | 08:07 PM
If that, considering over 50% of the paint is peeling. What's a decent paint job run these days?
Old Jun 5, 2015 | 08:14 PM
What do you know, last night I sent an email questioning his irs suspension and he removed it from the ad today. Maybe I should ask him about the 30 mpg.
Old Jun 5, 2015 | 08:24 PM
more than the car would be worth in perfect as-new condition :-/
the clearcoat is failing on my mechanically near-perfect 1992 740T wagon... a quality full car repaint would be $6 or $8K around here, and it still wouldn't be as good as the original. even doing just the hood and roof (the main parts that are failing) would be $$$$.
Old Jun 5, 2015 | 08:35 PM
Wow! They've gone up quite a bit since the last time I checked. You're right, if he gave me the car I still wouldn't put that much into it. Years ago I did do my own prep work on a Volkswagen and had the local high school auto shop class spray it...and from 2 miles away it looked pretty good.
Old Jun 5, 2015 | 08:38 PM
I guess I should watch out for ads where they say they're selling their "beloved"?
Old Jun 5, 2015 | 08:44 PM
You seem to know a lot about the 740-940 series. Let me ask you, I've been looking for a low mileage 1993 or later model because of the L block with oil squirters. Do you think they we're a major improvement to the engine? I heard they don't have the piston slap of earlier ones because of tighter tolerances. Is that so?
Old Jun 5, 2015 | 08:49 PM
heh. if you do your own prep, take off all teh lights and bumpers and trim and stuff, do all the sanding and stripping, laying down some rattle can primer to stop rust, then tow the car into a paint shop, you can get a small local kinda shop to shoot the paint for a lot cheaper than that.
I'd love to have the patience to do a paint job myself but I just don't. its not really that hard, you can even do a good job with quality rattle can paint if you don't want to use a compressor and paint sprayer, its all in the prep and wet sanding. and time and time and time again.
its beginning to look like we may end up volvo-less. we're selling our old 240, and next fall, thinking of getting a 4x4 SUV or pickup-with-shell for adventures, if we get that, my totally sorted out 740T wagon will be surplus, and that will leave us with said (probably Toyota) 4x4, and 3 Mercedes w124 family (daughter's 260E sedan, wife's E320 wagon, and my 300CE cabriolet).
Old Jun 5, 2015 | 08:51 PM
  #17
I thought the L blocks with squirters were only on the 94/95 turbo 940's.
I'm still kinda annoyed, one of the first 7/9 wagons I looked at was a low mileage white 95 940T wagon that was in very good condition, albeit a bit pricey ($4500 or something). I hemmed and hawwed for a day, and it was gone.
Old Jun 5, 2015 | 09:09 PM
  #18
lev's Avatar
lev
L blocks started in 1993, and the reason they don't SLAP is because of a longer piston skirt. Piston slap is due to the piston moving laterally in the cylinder, having shrunk due to overheating, then shrinking. That famous "squirter" motor is a bit of an overkill, the regular pre '93 motor is plenty good enough for any use.
1993 and later are better as they have bigger tanks, R134 refrigerant, electric fans, pass. side airbag (1994-5), and are well, the last 940, and the newest.
Old Jun 5, 2015 | 09:27 PM
  #19
You know I was puzzled for a long time that an engine with that much slap would be known for it's longevity. But if the wider clearance allows more oil up and alongside could that be the reason?
Old Jun 6, 2015 | 12:37 AM
  #20
lev's Avatar
lev
The piston slap happens if a b230 is overheated, but not enough to cause other damage. The metal stretches/shrinks and the piston moves a bit causing the slap. Not all b230 get this, obviously they all don't get overheated. The affected engines can last 100k miles more slapping, sound like diesels, more noticeable when cold-- not a desirable feature... BTW, the rings are not affected, just the piston itself shrinks, so oil, compression, etc. are not really affected. With the head off, you can actually move the piston back and forth with your hand, hearing the "slap". The longer skirts of the later motors make the slap much less likely. Still, you don't want a "slapper" if at all possible--turbos are more prone as they heat up more, and more have the slap than NA motors; many turbos will slap at start up, less when warm as the pistons expand. There is really no cure for piston slap other than new pistons.
