1995 940 Skipping
Old Apr 11, 2016 | 08:30 PM
Cboyz's Avatar
Default 1995 940 Skipping
My N/A B230F in my 1995 940 is skipping & missing at idle & taking off from low RPMs when the engine is warm. I've replaced spark plugs with no change, checked fuel pressure(38-40 at idle & 38 when revving, holds steady at both), I've unplugged the idle air valve to see if it changed anything but it didn't. I will be changing the fuel filter tomorrow to see if that helps but I'm honestly at a loss.. Help?
Old Apr 11, 2016 | 09:34 PM
lev's Avatar
lev
Leave that Fuel Filter alone, it's not the problem! Most likely it's the fuel pump, if the "tune up" related parts are all in good nick.
Old Apr 12, 2016 | 12:56 AM
small air leaks in the intake path can cause stumbling at idle and at low RPMs, that will generally smooth out once the engine revs up some, because they make it run too lean at said low speeds.
Old Apr 12, 2016 | 08:41 AM
Cboyz's Avatar
Would that show up on a vacuum gauge? I hooked one up & it was running about 20hg at idle.
Old Apr 12, 2016 | 01:41 PM
Nichals's Avatar
whats the spark plug wires, cap and rotor look like?
Old Apr 13, 2016 | 01:26 PM
Cboyz's Avatar
One of the plug wires were bad... Ohm'ed them out & found #1 to be low resistance.
1998xc70
2001-2013 model year XC70
Feb 13, 2013 08:00 PM
pdieni
Jul 26, 2011 08:14 AM
ringo
Mar 15, 2010 08:05 AM
99S70GLT
Jul 19, 2009 10:24 PM
GaryBrad
Apr 24, 2007 11:48 PM
