1998 940T manual. Engine sound.
Old Jul 11, 2021 | 05:16 PM
SalvadorP's Avatar
Default 1998 940T manual. Engine sound.
Does this car sound alright to you?
Old Jul 11, 2021 | 05:35 PM
There's something making a funny noise - if it's a bearing noise need to put a stethoscope on timing belt tensioner bearing, water pump, alternator,ac clutch, - manual trans - does the noise change when you push on the clutch?
Old Jul 11, 2021 | 05:55 PM
SalvadorP's Avatar
This is a car I'm looking into buying. But since it's 650km away, i asked the guy to send a video of the car running.
This is all I've seen, so i can't answer your question.
Old Jul 11, 2021 | 05:59 PM
SalvadorP's Avatar
In your opinion, can it be something real bad? The car costs 1500, and exterior and interior both look great so I can't expect perfect mechanical condition, I guess.
Old Jul 11, 2021 | 06:07 PM
sure, say its the throw out bearing on the clutch. if you can't do the work on your own, figure $1000 to drop the tranny to access the part and do the clutch while you're in there. Say its a timing belt tensioner - are you able to do the repair yourself? Figure $500 to have a shop do the timing belt. Maybe its the AC compressor clutch... you get the picture.
Old Jul 11, 2021 | 06:16 PM
SalvadorP's Avatar
I mean to try to do most of the work myself. But some i obviously can't. Removing the tranny wouldn't be something i would be able to do.
I'm wondering if this car is worth pursuing.
Old Jul 11, 2021 | 06:24 PM
SalvadorP's Avatar
Guy said the timing belt was changed about a year ago. But they all say that.
Old Jul 11, 2021 | 08:29 PM
lev's Avatar
lev
You are in Europe so quoting US prices is useless. A lot of Volvo repairs are easy comparatively speaking but still, it takes some tools and skill, and willingness to get dirty. But I like this car! I'd buy it in a second if it is what I imagine it to be...
Old Jul 12, 2021 | 06:36 PM
It may be worth paying to professional inspection done. If the noise is in the accessories / belts then you probably resolve the issues on your own. If the noise is in the clutch its a more complicated repair but can also be done with a helper provided you have the tools and a good place to work.
Old Jul 13, 2021 | 01:53 PM
SalvadorP's Avatar
Yeah, a placer to work would be hard at the moment. Would have to rent a garage just for the effect. Not ideal.
Since to not be clutch. I aked the guy to do a small test. Sound ain't perfect, but seems to be belt related.
b_eze
Sep 4, 2017 02:24 PM
RjsS60
Mar 7, 2016 05:44 PM
PetarYanev
Jun 9, 2013 12:02 PM
androide016
Apr 30, 2006 04:07 AM
