2-3-2 code?
Old Nov 12, 2007 | 10:40 PM
fordlovinfarmer's Avatar
Default 2-3-2 code?
I am getting a 2-3-2 code on my 1990 240 dl. What could be causing this? I don't know anything about these. I bought it for $500 with 311,000 miles and this is the first problem I've had.
Old Nov 12, 2007 | 11:09 PM
dgm76513's Avatar
Default RE: 2-3-2 code?
Long term fuel mixture too lean at idle.
Old Nov 12, 2007 | 11:42 PM
tripleb's Avatar
Could be a vacuum leak.
Check all the vac hoses and intake gasket.
How is the engine running?
Old Nov 13, 2007 | 06:15 PM
It still runs pretty good. I started to leave work the other night and it idled really high and when I started moving it chugged pretty bad. So I thought the tps was bad or had a bad connection. I wiggled the plug a little bit and it started to stall. Then I unplugged the air flow meter and started it thinking that was bad, but it didn't make a difference. Ever since I did that the check engine light has been on and it has been running fairly well. I checked all the vacuum hoses I could and there all in good shape.
Old Nov 13, 2007 | 06:49 PM
tripleb's Avatar
What you need to do now is erase the codes in the ECU. There should be a fuse for the ECU, but I'm not sure which one it is.
Is there a fuse by the l fender, near the power steering pump?
If so, pull that fuse, and re-install it and start the car. The CEL should be off, and see if it runs any different.
Old Nov 13, 2007 | 07:17 PM
I'll try that. Thanks
Old Nov 17, 2007 | 12:58 AM
martuna1's Avatar
I was getting that on my 1990 240dl recently, too. I brought it in and my mechanic told me it was a result of me having misthreaded one of my spark plugs. Did you recently change your spark plugs?
91shelby
Feb 4, 2011 08:24 PM
Elsid
Sep 9, 2010 08:42 AM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
