240 differential pinion nut torque
Old Sep 14, 2013 | 07:05 PM
busdude2's Avatar
Default 240 differential pinion nut torque
I just replaced the pinion bearings in a 89' 240 wagon. The book calls for a pinion nut torque of 148 - 180 ft.lbs. When I torque to this spec. the pre load is way too tight. I used blue locktite on the nut, and tightened to about 40 ft lbs to get the desired bearing preload of 2 ft lbs. Is there something I am missing ?? I used the old nut,and new bearings. When I disassembled the pinion, it took at least 200 ft lbs to break it loose, and I made a reference mark on the shaft and nut. Now my reference mark is 1/4 turn away,and the pre-load feels ok.
Old Sep 14, 2013 | 07:41 PM
guest01's Avatar
I suck at rebuild rear ends. When I do pinion seal I just go by feel.
So you replaced all the bearings? both on the pinion and carrier bearings?
Old Sep 14, 2013 | 10:48 PM
busdude2's Avatar
The pinion bearings,and wheel bearings. The differential carrier bearings looked good. I set the preload at 25 inch pounds, which felt a little tight. The specs. I found searching the internet. Even though the axle parts are all stamped Volvo, several forums say this is a dana 30 axle,same as the CJ jeeps ? The Bently manual has no differential specs.
Old Sep 15, 2013 | 01:40 AM
guest01's Avatar
That's european for yea. Lack of information.
Old Sep 15, 2013 | 06:18 PM
yes, its a dana 30 design, manufactured by volvo.
Old Sep 16, 2013 | 07:24 PM
actually, there's several complete greenbook on rear axle repairs.
http://www.k-jet.org/files/greenbook...le_repairs.pdf is one.
and, on page 15, sure looks like 150-185 ft-lbs if its installed correctly. or 175-220 ft-lbs if you got that one version.
Old Sep 16, 2013 | 10:08 PM
busdude2's Avatar
Thanks Pierce. I drove the car to work today, 104 miles round trip,and it's quiet now. I'll keep your greenbook specs handy in case I have to go back in for some reason. The worst part about this job,was installing the parking brake assembly.Many cuss words !!
dpagini
Jul 2, 2014 07:31 PM
daver80
Apr 22, 2011 11:16 AM
chadinator
Oct 27, 2010 02:30 PM
costys
Aug 19, 2009 12:16 AM
ohioS80
Dec 24, 2007 07:04 PM
