240 gauges to fit original optional spaces
Old Sep 23, 2014 | 10:43 AM
Bill-in-BR's Avatar
Default 240 gauges to fit original optional spaces
Hi all,
Some time ago I saw an outfit that supplies gauges to fit the pop-out filler blanks in my 93 240 wagon dashboard next to the instrument panel. They had many and came with a little panel that would fit into the spot left by the blank plastic filler plate. I would like to put in a small tach and outside temp gauge.
Now that I finally decided to do this, I have looked EVERYWHERE on line and can't find the supplier again.
Any help with this from you all would be greatly appreciated.
Thanks very much in advance,
Bill
Old Sep 24, 2014 | 07:31 PM
lev's Avatar
lev
Never heard of such a place, not to say it doesn't exist. You can get a Volvo OEM tach from a 240, they are common. An outside temp gauge for a 240, not so easy--they are pri$ey... like $200...
Old Sep 27, 2014 | 10:25 PM
240 Guy's Avatar
Try VDO cockpit series gauges fit and they have the same look as the other gauges.
Old Sep 28, 2014 | 04:04 PM
zjinqui1k's Avatar
These gauges are a standard size... 52mm. VDO, AFAIK, made the the original volvo gauges, and they were simply rebranded for volvo. As said, above, the VDO cockpit series gauges probably will look most similar.
What you probably need is the trim pieces, because the plastic for the gauges to fit in is already there. I usually look on ebay...
Volvo 240 Gauge VDO Plastic Trim and Rubber Feet | eBay
This is probably what you need. Then the gauges, you just slide in (with the feet) and put this over it. Voila! what could be eaiser?
You can also find many guages on ebay. I found all of mine there:
Best of luck.
Old Sep 28, 2014 | 04:15 PM
zjinqui1k's Avatar
Finally re-read this.... for an ambient temp gauge, I'd probably recomend this:
397-154: Vision Black Outside Temperature Gauge | VDO Gauges | eBuggies.com
One of these days, I plan on getting this.
You can find volvo branded ones on ebay
Volvo 240 Turbo GL GLT Outside Temp Gauge w Sender Celsius Good Shape Works | eBay
such as this, but they want too much. Eguages is cheaper, it's vdo, and it is new.
Old Sep 30, 2014 | 01:16 AM
Bill-in-BR's Avatar
Thank you all for the information and valuable links.
I will now pursue what you've sent and continue to make little improvements to the 240.
As always, the forum members prove to be the best.
Bill
awoyoshix
Feb 11, 2014 11:10 PM
wagone1
Sep 7, 2010 11:12 PM
Hi555
Feb 17, 2010 10:54 AM
brandons80
Jul 9, 2007 04:46 PM
bli745
Oct 31, 2006 04:02 PM
