240 Head rest removal
Old Feb 2, 2007 | 02:23 PM
Volvo240guy's Avatar
Default 240 Head rest removal
Im in need of replacing the front headrest on my 1993 240 sedan how do you take it off help!!!!!
Old Feb 2, 2007 | 08:49 PM
Default RE: 240 Head rest removal
I think they just pull off.
Or feel good on the back of the seat for a little button that will release the headrest.
Old Jul 30, 2009 | 01:27 PM
pcarsrule's Avatar
I replaced my front passenger seat upholstery last night.
The headrest mounts are retained by 2 plastic keepers (per headrest) inside of the seat. These keepers must be rotated 180degrees in order to remove the headrest. You can see the keepers inside the seat if you remove the upholstery.
I suppose if you can depress the seat upholstery enough (around the 2 mounting points of the headrest) you might be able to rotate the keepers.
I suspec that forcing the headrest out (without rotating the keepers) will result in damage to the seat.
Good Luck,
Don
jbr
Aug 19, 2009 09:12 PM
PieceKeeper
Dec 17, 2008 06:08 PM
volvo_s70
Nov 21, 2008 07:46 PM
volvo_s70
Nov 11, 2008 10:54 AM
skipb
Jul 6, 2006 10:45 PM
