240 Odomoter failure
Old Jul 6, 2013 | 10:24 PM
KMD's Avatar
KMD
Default 240 Odomoter failure
The odometer on my 240 stopped working at 159,9xx miles (since ive had it). On craigslist I see other people with the same problem at about 160k. Is this a common issue with 240s?
Heres a pic of my car, too.
Old Jul 7, 2013 | 12:29 AM
piv15's Avatar
It is indeed a common issue. Mine went out a little over 300000 miles. IPd sells a kit with instructions for replacing a gear that goes bad. I did it to my car. It was quite easy. Took me about 15 minutes. Does your instrument cluster light well? If not you should replace bulbs while you're back there too.
Here's that kit: 240 Odometer Repair Kit
Hope this help!
Evan
Old Jul 8, 2013 | 12:18 PM
Randydeadly's Avatar
Hi l have 1989 240 Volvo that the speedo is out of wack by 30km. it doesn't jump around like other volvo's l had. It has a reset switch in the back of the cluster. Can you tell me how to fix this problem?
englishman
Mar 14, 2022 02:57 AM
Robert Wilson
Feb 15, 2013 03:37 PM
jasonthaynes
Dec 2, 2012 05:32 PM
kosmoscanyon
Dec 16, 2008 12:39 PM
