240 Power Window Ground Connection Broken
Old 01-28-2012 | 06:02 PM
newmex999's Avatar
Question 240 Power Window Ground Connection Broken
The ground wire that runs to the drivers side power window switch must be broken because all of my windows stopped working. If I run a temporary ground to the switch then all windows work.
What is the best way to run a permanent ground to the switch? Can I do it somewhere inside the door, or do I need to run it through the hinge area and ground it behind the fuse panel somewhere?
Thanks
Old 01-28-2012 | 10:52 PM
Pugluvr's Avatar
I had the same thing happen - lost my ground to the driver side switch array. I spliced in a new wire, found an accessible screw in that door's inner frame and connected to it. Is that OK to do? I don't know but it works for me.
phaedrider
05-05-2017 05:42 PM
ingydrummer
02-18-2014 08:14 AM
pete77gg
10-22-2012 11:30 AM
dman777
06-06-2009 09:03 PM
