" power steering service required" bad sensor ? Relay? or connection?
Old Apr 17, 2010 | 02:09 PM
jaime1970's Avatar
Default " power steering service required" bad sensor ? Relay? or connection?
I have a 1999 s80 t6 with variable speed assist power steering.
My steering is hard... I had the rack and pinion rebuilt (it was leaking) after that the steering started getting hard but no messages on the dashboard. I changed the pump but no change on performance.
I was told it could be the Sensor on the rack and pinion or a relay / control unit by the gas pedal (part # 8690281 ). Can anyone help find out what is wrong with this steering and how to test both parts?? Thanks
Old Apr 26, 2013 | 08:07 PM
fabusi's Avatar
Hi Jaime
You need to change the lower steering column joint. This is the problem. As it wears it starts to bind. This part is made of aluminum.
Regards,
fabusi
bobinyelm
Apr 14, 2022 01:46 PM
buckle17
Aug 11, 2011 02:04 PM
bobinyelm
Nov 23, 2010 09:23 PM
chrissygm
Sep 30, 2008 05:53 PM
ShowtimeT6
Jan 1, 2006 11:56 PM
