240 shifting problem. very interesting findings
Old Dec 17, 2009 | 11:59 AM
sofobvolvo0909's Avatar
Default 240 shifting problem. very interesting findings
hey guys. I have a very odd problem. I recently got home from a 500+ mile trip. I came home on monday and then today i took the car for a test drive as i am installing a cruise control system. It started right up. I started driving and noticed it was not shifting right. It did finally shift but really high and it was a very hard shift. I disconected the cruise control so i doubt it was the cause. I turn for home and checked the trans fluid which was changed about 1000 miles ago on thanksgiving. (Mostly highway miles from delaware to charlotte NC and back.) The fluid was VERY VERY HIGH. It was above the dip stick plastic. I then drained some fluid and brought it back down to a normal level. and went for another drive. The problem was the same. Still not shifting at the right point and when it did finally shift into second it was a hard shift and at about 35mph instead of 15 to 20mph. As i pulled back into the drive way i noticed that when i put the car in park it felt different. I shifted back to reverse and it made the car jump or lurch. Then i shifted to neutrel and waited a second . Then into drive and it "jumped" again. The fluid in the trans is still red and looks good. What happened?
The car sat slightly uphill (about 5 degrees) nose up from monday night to today. When i drove home on the trip there was no problems at all. Ran strong and shifted perfectly. I am very confused
HELP PLEASE
Old Dec 17, 2009 | 12:09 PM
adub96's Avatar
sounds like a valve body problem
Old Dec 17, 2009 | 12:22 PM
if it were the valve body wouldnt it have been bad on monday when i was driving back? how would it have gone bad?
Old Dec 17, 2009 | 12:36 PM
bubba240's Avatar
The fluid should be checked on level ground during idle after shifting slowly through all gears.
I would inspect the kickdown that goes from the throttle body to the transmission.
Old Dec 17, 2009 | 12:48 PM
yup that kickdown cable is the problem, I forgot about that cable. It doesnt seem to want to go back down to the trans from the throttle valve. How do i fix? or should i just replace.
Thanks
STEVE
Old Dec 17, 2009 | 12:59 PM
bubba240's Avatar
See:
http://www.brickboard.com/FAQ/700-90...ble_Adjustment
hardluck
Mar 3, 2012 02:20 PM
FirstTimer
Nov 3, 2011 03:15 PM
nikez07
Jan 7, 2011 11:33 PM
nicolaselias
Sep 18, 2009 08:51 PM
harebearva
Jun 19, 2008 06:51 AM
