240 sunroof leaks
Old Dec 27, 2010 | 07:35 PM
rosslake's Avatar
Default 240 sunroof leaks
I have a leak on the passenger side of my 85 240's sunroof. Any ideas on how to unclog the gutter hole? a long pipe cleaner? It's very rainy in NorCal this year, please help if you can.
Thank ye!
info@rosslakeacupuncture.com
Old Dec 28, 2010 | 12:29 AM
coonmanxyz's Avatar
You might try blowing compressed air (a blow gun end hooked up to a compressor) through the holes from either end. Otherwise you will need quite a long wire.
Old Dec 28, 2010 | 11:21 PM
swiftjustice44's Avatar
Using compressed air or even a wire is risky business as the drain hose runs through the A pillar and after this many years can easily be damaged. I use a vacuum first and then gently force water from a hose into the upper drain. Once I determine from the dripping water which drain on the bottom pinch weld goes to the SR drain hose, I work from the bottom up. Often times it is nothing more than mud blocking the exit hole. If you do use compressed air..be VERY gentle.
Old Dec 29, 2010 | 08:57 PM
bicyclelifestyle's Avatar
had the same problem in my 740, took compressed air to the tubes and checked the weather stripping and fixed the problem for good.
alexdelove
Jul 29, 2010 05:11 PM
jeshokie87
Nov 30, 2008 11:40 AM
drzvolvobob
Feb 24, 2008 09:29 AM
jdbs3
Jan 17, 2006 05:44 PM
mktmkt
Mar 31, 2005 02:38 PM
