240 wagon headlight problems
Old Jan 21, 2007 | 06:19 PM
brohism's Avatar
Default 240 wagon headlight problems
I recently noticed that my right headlight was not working in my 1985 240 wagon. I checked the bulb, but it was fine. I turned on the high beams, and noticed that all the lights were on when I did this. The pictures below illustrate the problem:
Normal beams (notice that only the left side is working)
High beams (notice all lights are working, including both lights on right side)
I'm not sure what could be causing this problem. Any suggestions?
Old Jan 21, 2007 | 06:47 PM
JetTech's Avatar
Default RE: 240 wagon headlight problems
The low beam filament on your right headlight must be blown.
Old Jan 22, 2007 | 04:40 PM
brohism's Avatar
Ok, I'll replace the bulb. Thanks for the tip.
Old Jan 22, 2007 | 06:40 PM
Kruspe31's Avatar
I used to have that problem on my 740 tubro. I used to tap the light and it fixed it, then when that didn't work. I would unplug the light contector then replug it in and it worked.
Old Jan 24, 2007 | 09:08 PM
The wiring might also be bad.
wagoneer240
Mar 2, 2014 10:22 PM
Schaeffy
Jul 6, 2013 10:13 AM
TREMILOW
Jan 20, 2012 07:41 AM
Peter1234
Nov 23, 2010 01:19 PM
Gator
Jan 20, 2009 08:21 AM
