240 wont start-
Old Dec 17, 2008 | 04:25 PM
rsizzle's Avatar
Default 240 wont start-
i hook jumper cables to it and it starts but as soon as i remove them it stalls. any info is greatly appreciated.
Old Dec 17, 2008 | 04:52 PM
TIPSP's Avatar
Got Boost?
Default RE: 240 wont start-
Welcome.
You might need a new battery. How old is the current one?
Also maybe get the Alternator tested?
Most auto part stores can test the battery and alternator for you.
Old Dec 17, 2008 | 05:07 PM
If it dies when the cables are removed then the alternator isn't charging.
Old Dec 20, 2008 | 02:46 PM
bigdaddyrdpjr's Avatar
Definatly alternator. On older cars the batter just sarts it. If you unhook the jumper cable or the battery and it dies then the alternator is toast.
Old Dec 20, 2008 | 10:35 PM
sgtatarms003's Avatar
also when they check the altanator they test for a current. it dosent tell if it is chargeing i had to go through three from autozone before i got one that worked.
Old Jan 1, 2009 | 04:33 PM
rsizzle's Avatar
SoI placed a brand new battery and a new alternator in it. Then drove for aprox. 50+ miles. Everything went well untilI got close to home. Then the abs light came on and the lights started dimming. Upon arriving home it wouldnt restart. Anyone have any ideas. I have heard of the tail lights being problems. My 240 has a broken 3rd Brake light in the rear window.
Old Jan 2, 2009 | 08:12 PM
rockinriter's Avatar
Hey sizzle,
Go take your car to an auto parts store and have them check the alternator, not for the alternator being bad, but for the proper voltage coming off the alternator when running.
I had similar problems to yours and it ended up that the alternator belt was not at a proper tension. I tore my hair out after having replaced the alternator, the battery ground wires and still experiencing it dying. I took it to a friendly mechanic who himself had no answers until he double-checked the tension. Since then it's been charging fine.
Also during this trying period I checked the alternator wires leading back to the battery and to ground as these are routed under the engine and through an area that, I was told, has caused chaffing of said wires.
Good luck with it all.
Old Jan 4, 2009 | 01:27 PM
rsizzle's Avatar
thanks rockinriter! i tightened up that tensioner and it did the trick
Old Jan 16, 2009 | 10:44 AM
rsizzle's Avatar
it worked temporarily, now it ran fine until i went to target. it has full power but wouldnt restart. im lost
Old Jan 16, 2009 | 02:12 PM
soundmiami's Avatar
won't start as in won't turn over, or won't start as in something else got cooked?
Old Jan 16, 2009 | 02:27 PM
rsizzle's Avatar
as in wont turn over!
Old Jan 17, 2009 | 01:32 AM
rsizzle's Avatar
it wont even come out of gear
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
waltonsauto
Feb 1, 2012 10:31 AM
alex57
Sep 28, 2010 06:48 PM
furball3
Jan 28, 2007 03:31 AM
