242 engine harness problem
Old Sep 28, 2023 | 08:38 AM
CMF's Avatar
CMF
Default 242 engine harness problem
My 1981 242 arrived with the engine literally strapped to the crossmember with an old tow strap. The trans was in a trunk. I am just now trying to get it running, but discovered that the engine harness is toast. I’ve found a 1982 harness in good condition, but it contains a gray wire which was not present in the 1981 harness. According to everything I’ve seen, this should connect to a temp sender in the block above the starter. My engine has no such sender. Looking at the connector on the firewall there is a green wire at position 6. According to Dave Barton’s illustrations that is where the gray wire in the engine harness should connect.
Both the 1981 and 1982 harnesses are for the “mpg” version, with Chrysler ignition. Everything except the gray wire on the 1982 harness matches up to the engine and mirrors the 1981 harness.
Can I use the 1982 harness? What about the mismatch at position 6 on the firewall connector?
Old Sep 29, 2023 | 05:43 PM
ML1999's Avatar
Default New harnesses
Dave Barton in Texas is a Volvo Enthusiast who has mapped out all the schematics, and offers new harnesses. FYI. He has three useful websites.
Old Oct 10, 2023 | 09:12 PM
Johnsf's Avatar
The '81 Volvo Wiring Diagrams manual is excellent and downloadable for free at https://ozvolvo.org/archive.
britt441
Aug 21, 2019 12:41 PM
AnEskimo
Sep 17, 2014 01:00 PM
87 740 turbo wagon
Jun 29, 2014 12:02 PM
newmex999
Apr 23, 2011 10:09 AM
Rob27
Oct 16, 2009 11:17 AM
