740 driveshaft problem
Old Jun 13, 2006 | 11:44 PM
lotusing's Avatar
Default 740 driveshaft problem
Hey guys,
I notice that at a stand still when I accel at normal rate it seems like the drive shaft is hiting the bottom of the car for 3 seconds then stops as I go faster.Is there a center shart support bearing( like BMW's) or is there anther issue?
Thanks
Franco
Old Jun 14, 2006 | 12:34 AM
Default RE: 740 driveshaft problem
There is a center support bearing and carrier most likely it is bad.
zildjian's Avatar
Hello,
Yes you got it...! support bearing/cage. I would also check the Trans. mount as well as the exhaust sys. possibly hitting due to misallignment or trans. mount or etc...........
good deduction though...go for it!
take care,
Phil Franco
Old Jun 14, 2006 | 10:41 AM
lotusing's Avatar
Thank you very much for the quick help.You guys are incredible!!!!!!!!!!!!!!!! I will let you know what the verdict is for future reference.
Franco
Old Jun 14, 2006 | 11:58 PM
lotusing's Avatar
Thanks guys.It is the U joints and center support bearing.
Franco
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
dragon19a
Jan 15, 2007 09:19 PM
Walter J.S.
Apr 16, 2006 10:12 AM
Eli_T
Jul 1, 2005 03:26 AM
