740 ecu swap?
Old Jun 2, 2015 | 08:22 PM
Richyrich514's Avatar
Cool 740 ecu swap?
I forget where i read it, but i remember reading somewhere that i can swap an ecu from another volvo into my car and it will run better..
I have a 1986 740 GLE wagon - non turbo
Your input is greatly apreciated!
Old Jun 2, 2015 | 10:39 PM
is that car Regina or Bosch LH 2.2 ?
if its Bosch LH, there's some acceptable substitutes here. you need to know if your car has EGR or not, etc. https://www.volvoclub.org.uk/faq/Eng...ReferenceChart
if its Regina, afaik, you can only use another of the same part number Regina ECU, and noone has compiled a list of these.
Old Jun 2, 2015 | 10:54 PM
My car is a bosch with no egr
Old Jun 2, 2015 | 11:03 PM
then if your ECU is a 0 280 000 XXX where XXX is 541, 544, or 554, you can use any of those 3 ECUs, which might be found in a 240 or bosch 740 from 1985-1988. if you have a 511, then the table I linked doesn't give any substitutes, but its still quite possible any of those others are interchangable (these tables aren't perfect). afaik, 240's are all bosch, while 740's can be bosch or regina. 740/760/780 turbos are also bosch lh 2.2 in those years and may well have interchangable ECU's.
these ECU's are generally really reliable, are you SURE yours is bad? 1986 is a bad wiring year (1982-1987), you could have crusty flaking insulation in wiring main harness, which would cause all sorts of erratic behavior
Old Jun 2, 2015 | 11:10 PM
I was just trying to find out if there is an ecu i could swap in to make the car run better? Like i said in the original post i thought i read that somewhere and am curious to know if this is true. If i am able to put lets say the turbo ecu in my wagon is that known to run more smooth etc
Old Jun 2, 2015 | 11:13 PM
your car should run as optimally as it can with the stock ECU. what are the symptoms you're trying to fix ? its a 2.3L 4-cyl from the mid 80s, that won't run as smooth as some modern V6 or whatever, but it should idle steadily and rev just fine, within the limitations of the stock about 115 horses...
Old Jun 3, 2015 | 02:01 AM
Old Jun 3, 2015 | 06:07 AM
act1292's Avatar
What do you mean by "run better". If your car isn't running properly, post what your problem is and the folks here will be more than happy to help you to diagnose and fix it - most likely without swapping ECUs. If you are trying to make more horsepower, then you might want to try Turbobricks where they talk about all kinds of ways of making more horsepower.
Old Jun 3, 2015 | 09:03 AM
lev's Avatar
lev
I wouldn't put too much hope in swapping ECUs to make this car run "better"! ECUs rarely go bad and if they do, they don't do what you are trying to cure. Blaming the ECU is an easy way to blame the evil "computer" for undiagnosed problems.
Alan Eliass
Oct 29, 2013 09:04 AM
makaveli2k
Aug 8, 2012 12:32 PM
matt01
Jul 23, 2012 11:12 AM
91shelby
Jun 20, 2011 06:56 PM
bigern45
Aug 5, 2008 08:14 AM
