740 front brake caliper type
Old Aug 17, 2020 | 03:45 PM
peetcg's Avatar
Default 740 front brake caliper type
Changed the right couple years ago but no record of brand/type. Now need a left!
It has front ABS only.
If you recognize this one please let me know! Parts stores offer 3 styles.
TY!
Old Aug 17, 2020 | 04:05 PM
[QUOTE=peetcg;489095]It has front ABS only.
Can't help you with the brand but you have ABS on the rear wheels also - the ABS system uses the speedometer sensor in the differential to know what's happening with the rear tires.
Old Aug 17, 2020 | 06:41 PM
re: the caliber... I see two pistons on the inside, are there two more pistons on the outside, or is the outside a moving piece that gets pulled together by the inside pistons as they push against the rotor? What year 740 is this, turbo or non-turbo ?
btw, first pick, your rotor looks pretty deeply worn, you should use a brake disk gauge to measure how thick it is, and if its even close to the wear limits replace it along with the pads, same on the other front side...
Old Aug 17, 2020 | 06:54 PM
I believe thats an early style (up to 1990) Girling ABS. see
https://www.ipdusa.com/products/8639...rebuilt-5e9031
https://www.ipdusa.com/products/8638...rebuilt-5e9032
the 91+ Girlings are single pot, not double pot, and the DBA/Bendix hgave the bleed nozzle at a different angle.
btw, thats a very good site to get Volvo parts, as they started as a purely Volvo specialist and are one of the largest Volvo repair shops in the greater Portland area where Volvos were once really common. They've expanded to Subaru and other makes to keep in the market, but still fully support Volvos.
Old Aug 18, 2020 | 06:34 AM
peetcg's Avatar
perfikt people. It is a '90 with turbo and sliding arrangement 2 piston type [if i remember correctly]. That ABS configuration I never would have surmised- thanks for all info-
believe i can move along with this.
Best-
740>Hammer
Jul 3, 2020 07:52 PM
Nick0187
Jul 27, 2018 08:43 PM
92Sedan
Jan 10, 2016 02:18 PM
ayedurand
Jan 19, 2013 01:19 PM
crazynlazycolombian
Jul 30, 2006 09:46 PM
