740 lower control arm
Old Jan 22, 2019 | 10:01 AM
jagtoes's Avatar
Default 740 lower control arm
Starting to look at doing my 89 740 front suspension. Looking at my green book service manual it tells me that my year ( USAand Canadian) has the aluminum lower control arm. I have not found an aluminum replacement but plenty steel ones ranging from $35 to $150. I can also just buy the bushings but just considering the easy way. It seems the control arms are a direct replacement but with the steel ones it looks like you need to replace the sway bar ends too as they are different. Just asking if anyone has done this replacement with steel and did you run across any other differences. By the way at 375K my bushings are rock hard
Old Jan 27, 2019 | 12:35 PM
admasters's Avatar
Just a thought. If the subframe bushing is good then skip it and replace the strut rod bushings (and others). I guess it depends how deep you want to get into the project.
dytha99
Nov 6, 2015 05:46 PM
madymo3d
Jul 29, 2014 10:33 AM
MEWEAVER
Aug 5, 2013 12:14 PM
vrktring
Nov 21, 2011 09:24 PM
phoffman
Sep 2, 2007 03:07 PM
