740 occasional stalling
Old Dec 18, 2008 | 09:31 AM
kai's Avatar
kai
Default 740 occasional stalling
Hi everyone.
I am new to the volvo family with a relatively new purchase of a 1991 740. it ran sweetly for about 2 months, then started to stall occasionally, mostly when slowing down. after a couple of minutes it would start up fine again. problem started to happen more and more and the time it needed to start up again increasing. My dad put new plugs, dist and rotar arm in, and it still happened, so he took it to a garage who fitted a new coil. it still happened after this although less frequently, usually after about 15-20 miles or so and will fire up again after a few minutes. Took it to another garage who have shrugged their shoulders, saying it might be temperature related as it usually starts up again. I have read some posts and replies on here mentioning in tank pump and fuel relay. because it cuts out without spluttering i thought it was electrical rather than fuel? but i am no mechanic. any advice is greatly appreciated, could fuel still be an issue? thanks a lot.
Old Dec 18, 2008 | 11:23 AM
bubba240's Avatar
Default RE: 740 occasional stalling
I would start with the crank position sensor and the fuel pump relay.
http://www.fcpgroton.com/product-exe...ategory_id/111
Old Dec 18, 2008 | 07:15 PM
fredbyte's Avatar
Bubba's advice is good. Gremlins are hard to pinpoint though. Also try a new air filter. Then, put a timing light on it and check to see if the mark moves, which means the rubber dampener on the crankshaft pulley is deteriorating. Also, it may be that the timing belt is slipping.
Old Dec 19, 2008 | 08:17 AM
soundmiami's Avatar
I had issue with a faultly temp sensor fooling the ECU and kicking in the cold start injector whichrandomly flooded the engine but you would smell gas.
kpregan34
Nov 27, 2010 05:02 PM
dlk1
Mar 17, 2008 09:20 AM
t4 turbo
Sep 4, 2007 11:15 AM
dlk1
Apr 21, 2007 06:46 AM
loserking86
Dec 29, 2006 11:49 PM
