740 poor accelleration
I have a 1989 740 GL b230f. When I accellerate, the car spits, sputters and backfires. Turning on the A/C makes it even worse. So far I have replaced the O2 sensor, throttle position sensor, the ignition module, both fuel pumps. Two different shops looked at it and cannot figure out what is wrong. Any ideas?
Don't know if they checked the pressure under load or if the rear main was ever done. The main was not done within the last 2 years. The backfiring etc. is much worse under load and after the vehicle has warmed up. Unplugging the temp sensors doesn't change anything. I have replaced both fuel pumps and the fuel pressure regulator.
bjornthebull
Nov 29, 2011 07:41 PM
brf0007
Nov 8, 2010 11:35 AM
