740 wagon turn signal confussion
Old Jul 12, 2013 | 12:15 PM
KyleN20's Avatar
Default 740 wagon turn signal confussion
I recently bought new front turn signal lenses on replaced both of my old units. The one on the pass side had an amber and the driver side had a clear bulb with one of the two filaments out. in the condition they were in the blinkers worked normally (the out filament was the running light)
I recently replaced the drivers side blinker with a amber bulb, used dielectric grease, kept my oily fingers off the glass ect and it was fine for maybe a week. Now however it has developed the fast blink on the drivers side which is associated with an out blinker bulb so I figured it must be the rear now so I checked the rear and its good blinking as it should (also the other filament is good as I checked that. So then I thought great somehow my brand new bulb is toast (good thing it came with two) so I swing around to the front to check the front drivers side blinker and ITS WORKING FINE. so for some reason I have the fast blink which I thought means that the blinker bulb is burnt out however no bulb is burnt out.
My only other thought is it may be a relay however I would think that any relay would be associated with both the driver and passenger side and the pass side works properly.
Any help is appreciated
Old Jul 12, 2013 | 10:59 PM
lev's Avatar
lev
No relay problem. Check the bulbs and make sure they are seated correctly in the sockets, may be jiggle them a bit--the problem is in there.
suckonthiscaravan
Dec 5, 2018 03:19 PM
tigerheart3
Mar 29, 2013 12:45 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
chowderfoot
Jan 2, 2009 07:41 PM
