740GL starting problems
Old Sep 6, 2006 | 03:36 PM
penkogj's Avatar
Default 740GL starting problems
Problem:
89 740GL 4cyl. 8 valve won't start. Sounds like it isn't getting fuel. The engine just cranks but won't fire.
I checked the fuel pressure at the fuel rail and it is normal. If I spray starting fluid in the air intake the engine
will fire and burn it but not start so the ignition system is working. I suspect the injectors aren't pulsing.
How do I check if they are working and if they're not what could be the cause?
Old Sep 6, 2006 | 07:18 PM
bli745's Avatar
Default RE: 740GL starting problems
fuel pump relay or the silent late for work killer... "radio suppression relay" (under hood near PS fluid tank)
Old Sep 6, 2006 | 09:02 PM
ORIGINAL: bli745
Agreed.
The Black Relay could also be mounted at the coolant bottle.
Old Sep 7, 2006 | 10:56 AM
penkogj's Avatar
OK,
I took off the radio suppression relay and had it checked by a elec. technician I work with. He swears it is working ok.
I still think the injectors aren't pulsing. I can't here them when I have someone crank the engine. Where does the relay get its power from?
Old Sep 7, 2006 | 08:54 PM
Both the Black and white fuel pump relay controls the injectors.
wilderness
Dec 26, 2011 08:57 PM
dhinez
Sep 20, 2010 02:05 AM
Rottie95
Dec 10, 2008 02:02 AM
penkogj
Nov 30, 2005 08:07 PM
cpayette
Aug 12, 2003 08:24 PM
