'76 242 no start
Old Jun 1, 2008 | 01:47 PM
pushinmycar's Avatar
Default '76 242 no start
She won't start hot, she won't start cold. she'll only start after lifting the air sensor plate and getting gas out of the injectors and even then it's iffy. I've checked the cold start valve and it's good but it doesn't open when cranking and the thermal time switch is passing voltage. and even then the car doesn't start hot. I'm out of ideas.
thanks
Old Jun 5, 2008 | 07:40 PM
Beardog's Avatar
Default RE: '76 242 no start
huh. you might need to re-explain that
Old May 19, 2012 | 09:16 PM
AnEskimo's Avatar
I had a similiar problem in my 80 242. May seem simple but I had a bad connection on my fuse for the fuel pump relay I think 13. Separate from fuel pump relay. I didn't know there was one. Also check vacuum lines especially big ones on auxiliary air slide valve. Are you getting fuel to the injectors at all?
Old May 20, 2012 | 02:30 PM
pssst? this is a 4 year old thread.
Old May 20, 2012 | 03:50 PM
Joseph/TX's Avatar
The default settings on this site currently defy all logic...
Old May 20, 2012 | 04:01 PM
yeah, somethign is borked. it used to come up with the proper default of threads with newest posts first (after the stickys, of course).
Old May 21, 2012 | 09:48 AM
sicnarf's Avatar
Come on you senior members,use your influence and make it right then so the newest threads come out first automatically.
SmrkngRvng
Jan 31, 2014 12:13 AM
AnEskimo
Apr 24, 2012 08:10 PM
Alobar
Aug 2, 2010 10:19 PM
volvo 4 life
Aug 9, 2007 07:55 PM
Vanos
Aug 15, 2003 03:36 PM
