'83 242 DL - Battery not holding charge(?)
Old Nov 2, 2009 | 01:09 PM
KingDahn242's Avatar
Default '83 242 DL - Battery not holding charge(?)
Just replaced my alternator and battery, but the car is still sucking the battery dry. My assumption is something's preventing the Alt from charging the Battery.
Any tips/info/insight?
Old Nov 2, 2009 | 01:46 PM
bubba240's Avatar
With the key on make sure the battery light in the cluster comes on, and that you have ~2VDC on the small red wire connected to the back of the alt. before you start the car.
Old Nov 2, 2009 | 01:55 PM
No Battery light. And no volt tester... but that little red wire that connects to uh.. what looks like a senor os sorts going into the engine? Like 4in long thin wire?
Old Nov 2, 2009 | 02:24 PM
bubba240's Avatar
Attached shows the alternator connections.
There will also be a wire close by that goes to the oil pressure sensor in the block, unrelated to the charging system.
Old Nov 2, 2009 | 02:46 PM
Okay, everything's connected proper. Battery's dead though, and no volt tester. I charge the battery for a bit and the car runs, then putters to death. Is that big red wire the one responsible for keeping the battery charged?
Also, I think somethings pulling on the battery even when the car's off.
Edit: Alternator and battery both tested out good at Kragen
Old Nov 2, 2009 | 03:12 PM
bubba240's Avatar
It might be fuse 13 or the light might be burned out.
Without battery voltage being applied to the small red wire (through the batt light) the alternator will not charge.
Attached Thumbnails '83 242 DL - Battery not holding charge(?)-charging_system2.jpg
Old Nov 2, 2009 | 04:06 PM
What's that box at the top? Looking through everything... that might be where I'm having a connection problem
Old Nov 2, 2009 | 04:26 PM
Problem found. Mechanics that replaced the lead wire a couple months ago... didn't... connect it...
Old Nov 3, 2009 | 09:50 PM
varg's Avatar
Glad your problem is fixed, you wouldn't believe how often I work on a friend's car and find that the mechanics at the shop have botched something simple like that.
Old Dec 10, 2011 | 11:48 AM
Ms. Greenbike's Avatar
bubba240,
Having the same charging problem. After a new battery from one repair shop, a new voltage regulator from another, just checked myself to find fuse 13 missing. If this solves my problem I owe you big, big thanks!!
AnEskimo
May 8, 2010 09:49 AM
darkdelta
Jul 19, 2009 12:23 PM
ricky
Jan 27, 2009 07:31 PM
paul
Jan 4, 2006 07:04 PM
issyjosh
Apr 20, 2005 04:31 PM
