84 240 Extreme Knocking
Old Apr 19, 2014 | 09:07 PM
Volvo #14's Avatar
Default 84 240 Extreme Knocking
Hi guys. I have had volvos for the past 23 years. My son has an 84 240 sedan. The car runs decently until it finds a hill. Then it knocks and pings until it loses power and over heats. We gave it a tune-up, fixed any vacuum leaks and will replace an old O2 sensor tomorrow just for fun. Anyone have any suggestions? What about a knock sensor?
Old Apr 20, 2014 | 02:16 AM
check the timing advance with a strobe light?
which ignition system does that 84 have? is that the 'chrysler' ignition control unit on the right front fender, with the vacuum diaphragm right on the ICU ?
Old Apr 20, 2014 | 08:59 AM
Volvo #14's Avatar
Im not sure which system it is. I've tried to figure out how to adjust the timing. But dont know how. Distributor can't be moved. I assumed it was electronic since I can't find a vacuum advance anywhere.
Old Apr 20, 2014 | 01:42 PM
on the right fender wall, behind the right side headlight, is there a flat electroncis module, which has a vacuum bellow on the bottom forward facing side ? it looks something like this, but turned 90 degrees counterclockwise...
Old Apr 21, 2014 | 11:26 AM
Volvo #14's Avatar
Thanks! I found it and was able to adjust it. Adj. bolt was hidden under wires behind distributor. Seems to be working well now.
LOVEvolvos
Apr 24, 2012 10:36 PM
bpmarkham
Feb 24, 2010 11:45 AM
jmarble
Dec 27, 2009 09:36 PM
tomeldan
Sep 17, 2005 06:19 AM
heyzerg7791
Jul 30, 2005 09:37 AM
