'84 240 turbo coupe sagging in the back end
Old Aug 17, 2009 | 01:50 AM
petemoffat's Avatar
Default '84 240 turbo coupe sagging in the back end
Has anyone had a similar problem if so what did you do to fix it?
Thanks!
Petemoffat
Old Aug 17, 2009 | 01:58 AM
TIPSP's Avatar
Got Boost?
check bushing wear.
The shocks will probably need replacing and also the springs.
Wait for the experts to get on
Old Aug 17, 2009 | 02:15 AM
petemoffat's Avatar
Thanks Tipsp,
I did put new shocks all around five years ago and probably have 6000 miles on it since then! I will have a closer look at them and the springs etc.
'04 XC70 (family)
'92 240 DL wagon (son)
'84 240 turbo coupe (mine, parked in another city)
Old Aug 17, 2009 | 03:26 AM
TIPSP's Avatar
Got Boost?
what shocks? that is not a lot of miles on them in that time period. they a probably still okay...
only the springs might needing to be replaced.
Old Aug 17, 2009 | 12:44 PM
blue goose's Avatar
Either bad trailing arm bushings or weak springs. Even with the shocks removed the car shouldn't sag. Fortunately the rear springs are pretty easy to replace if you have a floor jack and a couple of jack stands.
Old Aug 17, 2009 | 03:52 PM
petemoffat's Avatar
Thanks Tipsp,
I will make a trip to the wreckers for some newer springs.
Cheers,
Pete
Old Aug 17, 2009 | 03:55 PM
petemoffat's Avatar
Thanks Bluegoose,
The springs are the culprit by the sounds of it, are the trailing arm bushings relatively easy to replace as well?
Pete
Old Aug 17, 2009 | 10:22 PM
blue goose's Avatar
TABs are not easy to replace. This tool will help:
http://www-ese.fnal.gov/People/wilce...shing_tool.htm
Old Aug 18, 2009 | 03:19 AM
petemoffat's Avatar
That TAB info looks very thorough and should be helpful if I have to go that route.
Thanks again blue goose!
Old Sep 17, 2009 | 12:38 PM
Jetdog's Avatar
Default sagging issue solved
Replaced the rear springs on my '84 240 coupe with a set from a '90 sedan. The car sits more level and does not drag the tailpipe going into and out of the gas stations anymore.
Thanks for the advice gang!
leoinvegas
Dec 2, 2011 07:41 PM
plumonium
Apr 7, 2011 12:03 PM
turbo940v
Nov 13, 2010 11:27 PM
shelbylay
Nov 4, 2009 05:32 PM
92volvo960
Suspension
Nov 3, 2006 10:00 PM
