84 240DL Poor top end acceleration
Old Jun 9, 2006 | 11:12 PM
swsail's Avatar
Default 84 240DL Poor top end acceleration
Just bought ultra clean unmolested 84 240 (133k), ran perfect with pretty good acceleration when floored. After changing air filter, car runs smooth but acceleration is now very sluggish above 3000 rpm.
Old Jun 9, 2006 | 11:44 PM
Default RE: 84 240DL Poor top end acceleration
Recheck the filter and make sure nothing is stuck in the housing blocking flow.
Also there is a Valve in the Air box you might want to screw it open or remove it totally.
Old Jun 11, 2006 | 07:40 PM
swsail's Avatar
Thanks Tech,
I checked the filter, ok and valve is open, is it possible the air supply hose after the mass air sensor is torn? The car accelerates smoothly but weak under partial throttle, just really struggles under full throttle.
Old Jun 11, 2006 | 10:16 PM
Yes it is possible should be easy to spot.
Mike Lemon
Jun 10, 2015 10:45 AM
pisque
Aug 21, 2005 09:52 AM
Mcgurk
Dec 16, 2004 09:57 PM
