'93 940 poor acceleration
Old Aug 19, 2005 | 10:28 AM
pisque's Avatar
Default '93 940 poor acceleration
I read the diagnostic codes and got 1-4-3 in socket 6 and 2-3-2 in socket 2. I replaced the knock sensor and erased the codes but it returned. I checked the voltage at the knock sensor wires and it read zero. What unit sends that voltage to the knock sensor and where is it located. As for code 2-3-2, the car runs fine except for a rough idle. I've removed and cleaned the throttle body and the idle air motor. I've also had the injectors cleaned and there is no fuel pressure loss, so the injectors are not leaking. What else could be causing this? This forum has been a great help and I want to thank those who share their valuable knowledge with us.
Old Aug 19, 2005 | 10:43 AM
Default RE: '93 940 poor acceleration
Me I would start with the 232 code that means you have a vaccum leak somewhere making the computer adjust the fuel system to compensate.
That might be disabling the Knock sensor signal.
I would check and repair all vaccum leaks clear the codes and see what happens.
Old Aug 19, 2005 | 09:40 PM
Carbuff's Avatar
ORIGINAL: pisque
A 1-4-3 code is a knock sensor self-test code. My Volvo has been setting that code for many years (I have receipts from the P.O. to prove it). Every once in a while I work on it, but have not found anything definitive. Except that previous technicians have travelled the same roads as me already (evidence of voltage tests and socket backprobing abound).
There are discussions of this problem on the Brickboard FAQs
You can't easily measure the sensor output, its a tiny voltage. The self-test signal that generates the 1-4-3 comes from the ECU (in the right side kickpanel).
Doesn't the ECU switch to full retard of ignition timing when the 1-4-3 is set? That's the reason I always reset the code ASAP.
Old Aug 21, 2005 | 01:32 AM
elballoonrat's Avatar
im guessing this is the turbo 940 you guys are talking about since it has a knock sensor. do the n/a's have a knock sensor as well? my car is not quick but i didnt think anything of it but it may have the same problem although i dont have a check engine light right now.
do you guys use a paperclip to jump pins and flash the error codes or do you have to use a reader for the volvo's.
Old Aug 21, 2005 | 01:44 AM
Yes the N/A have knock sensors.
If it is a newer car and you have OBDII then you need a scanner If you have OBDI follow link.
http://www.troublecodes.net/Volvo/
Old Aug 21, 2005 | 09:52 AM
Carbuff's Avatar
ORIGINAL: tech
The car in question is a '93 940 so it has OBD 1. That Link (above) gets you to the code list and reset instructions. But it doesn't go into the Why of the codes' setting. The Brickboard FAQs do.
Aside from a bad sensor, the cause could either be wiring or the torque on the sensor mounting bolt...they have to be tightened correctly to work right.
chrome2386
May 28, 2013 09:56 PM
Rekhati
Jul 27, 2010 10:31 PM
swsail
Jun 11, 2006 10:16 PM
pisque
May 19, 2006 11:31 PM
Mcgurk
Dec 16, 2004 09:57 PM
