'85 240GL low idle
Old Jun 18, 2005 | 02:53 AM
macBdog's Avatar
Default '85 240GL low idle
Hi guys,
Had a search through the forums and couldnt find anything on this so I thought Id ask:
My 1985 240GL has a low idle. In park its only just acceptable (~800 on the taco) and in drive the engine is almost stalling. I have replaced the distributor cap with no effect and have also tried adjusting the idle speed using the adjustment **** under the intake plenum also to no effect. In the manual it says to ground a blue and white test lead near the battery before adjusting the idle speed but I can't find this lead anywhere!
Can anyone tell me exactly where the blue and white test lead is to adjust the idle speed?
Thanks,
Charles.
Old Jun 18, 2005 | 12:04 PM
Default RE: '85 240GL low idle
The first thing you should do id clean the throttle body and idle motor then take it from there.
yank50
Mar 14, 2009 11:15 AM
elderzap
Nov 7, 2007 04:58 PM
Steve240GL
Apr 30, 2006 11:16 AM
Flashback
Nov 24, 2005 02:29 PM
