85 245 wont start
Old Feb 5, 2008 | 07:28 PM
jeremy's Avatar
Default 85 245 wont start
i drove the car to work and came out to start it and nothing. i did some checking and there was no spark. did some further checking and found it was the hall sensor. i replaced that and now i have spark and fuel but still no start. not sure where to go next.
Old Feb 6, 2008 | 07:23 AM
jonesg's Avatar
Default RE: 85 245 wont start
Did it get flooded?
Have you tried a shot of ether ( Ishoot it in the vac hose at the back of the fuel pressure regulator).
Are the injectors working?
Old Feb 18, 2008 | 05:43 PM
jeremy's Avatar
no go with ether and not sure how to test injectors. i tried to remove the rail and injectors but they are stuck. i don't want to force them. any tips?
Old Feb 18, 2008 | 06:26 PM
Do you hear the fuel pump kick on?
If you could find a noid light you could plug it into the injector wiring and watch for the light to flash.
Old Feb 19, 2008 | 12:59 AM
rene's Avatar
I had intermittent start problems with my 86 240 wagon and found the fuel pump relay wasoriginal lol. Changed it and seems to be fixed. Cheers
Old Feb 19, 2008 | 09:57 AM
jeremy's Avatar
the relay clicks over when the key is turned to the on position and again when trying to crank. i can hear the pump and i get fuel going to the rail. what am i looking at if i do/do not have pulse at the injectors?
Old Feb 19, 2008 | 01:48 PM
jeremy's Avatar
got a set of noid lights and there is pulse going to the injectors. where do i go from here? could it be speed sensor? i'm stumped.
Old Feb 19, 2008 | 06:30 PM
It could be the speed sensor or the pick up in the Dist of yours has that.
Old Feb 19, 2008 | 06:34 PM
jonesg's Avatar
If it won't fire with ether you can't have good spark.
I pull the vac line from the FPR and shoot a good blast in there, it should run for 4-5 seconds on that.
Unless its completely flooded, in which case pull the plugs and the fuel pump relay, crank it over a few seconds.
Also smell the oil.
I've read of guys cranking their engine at nite with no lights around and seeing all the sparks escaping their worn out ignition systems HT wiring. If its a damp enviroment, spraying the plug wires with WD40 gets many balky engines going.
I find my cheapo timing light is good to checking for spark, but not quality of spark.
Old Feb 19, 2008 | 07:02 PM
jeremy's Avatar
hall sensor in distributor has been replaced. dist cap, rotor and wires are also new. i'll try to have someone start it while i spray ether. i have been doing this alone, so i would spray and then go try to start it. thanks for the help everyone.
Old Feb 20, 2008 | 11:59 AM
jonesg's Avatar
I worked on mine alone too, thats why I suggest putting the ether in the vac line going to the intake manifold, it works quite well.
If its got compression,
if the plugs aren't drowning in fuel (you didn't say one way or t'other..)
and you can't get it to pop with ether,
logically I'd sayits ignition related.
Old Feb 20, 2008 | 04:16 PM
jeremy's Avatar
i pulled the injectors and they are spraying just fine. i've got good spark on all cylinders, fuel from all injectors, i don't understand why it won't start. sometimes it will act as if it is going to fire for a couple of seconds but never does.
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
nmwagon
Aug 20, 2007 10:55 PM
nmwagon
Aug 17, 2007 11:04 PM
furball3
Jan 28, 2007 03:31 AM
